  #1
Old June 17th, 2008, 11:47 PM
viettim viettim is offline
Default RPM's not getting higher than 4,000 on Mercury 4.3l
i have a 2003 Mercury 4.3L V-6 in a Sea Ray 19' and i can't seem to get the engine to pull more than about 4,000 - 4,100 RPM's. it has a quicksilver 4-blade prop. any idea why it isn't hitting the 4400 - 4800 rated rpm limit?
  #2
Old June 18th, 2008, 06:52 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Default Re: RPM's not getting higher than 4,000 on Mercury 4.3l
Ayuh,....
It either needs a Tune Up,... or,.. The Prop is Too Big, drop some pitch....
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #3
Old June 18th, 2008, 09:16 AM
nlain nlain is offline
Master Chief Petty Officer
I have a 2004 SeaRay 185Sport with 4.3L 190hp, Alpha 14X23 Prop, don't remember the gear ratio, I have no trouble getting 4800 even with a full load. I think Bondo hit it pretty good.
__________________
http://myboat.wikispaces.com/
2004 Sea Ray 185 Sport, 4.3L,190, Alpha
1994 GMC 4X4 1500, 5.7L
  #4
Old June 18th, 2008, 09:47 AM
MikDee's Avatar
MikDee MikDee is offline
Quote:
A history of the boat would help, did it ever run 4400-4800 before? with any prop? or is this a prop you just recently put on the boat, and now it's not reaching this rpm? and what's the pitch on the 4 blade?
__________________
89'-19' Bayliner Capri Ski boat, with a 125hp Force
My Previous Boats http://smg.photobucket.com/albums/v2...ee/My%20Boats/
My motto - Keep It Simple Stupid
  #5
Old June 18th, 2008, 11:00 PM
thanks all. not sure if it ever did...i just got the boat a couple of weeks ago. the engine runs great, starts no prob, idles well, etc. i'm not sure the pitch but know it has a quick silver 4-blade prop. i'm thinking the first step is a new prop and then even an fuel intake cleaning would be good. any good suggestions on any additives that work well?
  #6
Old June 21st, 2008, 03:41 PM
bhammer's Avatar
bhammer bhammer is offline
I have a 06 4.3 MPI @ 220HP and have to run a 17" 3 blade to get to my RPM. Boat manufacturer sold them with 18" 4 blade but could never get WOT.
__________________
2007 Starcraft Limited 1900 RE
Mercruiser 4.3L MPI w/ Aplha
  #7
Old June 22nd, 2008, 02:20 AM
wca_tim wca_tim is offline
try looking at the prop for markings. May have to remove the prop nut to see them on the rear of the hub. Unless it is higher than a 23 or so, i would bet that you're in need of at least a full tune up (not just fuel additive... plugs, cap, wires, fuel filter, check and clean everything, etc, etc, etc...
my 4.3 in an 18 foot boat would turn a 26" prop to 4700... and 23 to 4800-4900, 21 4 blade to over 5000. I'm assuming that your boat is fairly light and that you don't have a monster mismatched prop on there. can't be sure until we know a little more... at least what the current prop is.
Cheers!
  #8
Old June 22nd, 2008, 02:41 AM
bhammer's Avatar
Cheers!
Wow, what drive ratio do you have? I only wish I could get that out of my 220HP. Now, I do have a 3000# boat and I am sure that has some to do with it. Sorry to get away from teh OP.....
__________________
  #9
Old June 22nd, 2008, 03:38 PM
thanks everyone. i am putting on a 14/24 3-blad prop to get back more to stock. i'll take it out next weekend and see if that's the ticket.
  #10
Old June 22nd, 2008, 03:59 PM
MikDee's Avatar
That sounds like way too much pitch for that boat combo! I'd say maybe a 19", or 21" pitch, max,,,, You really need to find out whats on there first before you go, and throw anything on. Usually, one step up in pitch is required with less blades, so if it was an 18" pitch 4 blade, a 19" pitch 3 blade would be in order.
__________________
  #11
Old June 23rd, 2008, 04:00 PM
that's good advice, i found a guy who is willing to let me try a few before i buy. sounds like that's the way to go. what about stainless vs aluminum?
  #12
Old June 23rd, 2008, 05:41 PM
MikDee's Avatar
IMO, stainless don't spool up as fast as aluminum, (it works your engine more) but holds steady fixed speed like a rock, will give you more top speed because it's rigid, and can be run higher out of the water, especially when trimming, but it's heavier.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Boat won't go over 4,000 RPM's AaronWhitt82 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 25 June 18th, 2008 12:01 AM
Bogging down at higher RPM's dvan1901 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 April 1st, 2006 05:51 PM
1995 Force 120. Bogging @ 5,000 rpm's Ransan12 Force & Chrysler Outboards 8 July 27th, 2005 09:49 PM
Over 7,000 RPM's SASS Mercury & Mariner Outboards 1 July 31st, 2003 04:38 PM
higher RPM's? wilkin250r Non-Repair Outboard Discussions 1 February 10th, 2003 04:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
