  #1
Old June 17th, 2008, 08:45 PM
Mark42's Avatar
Mark42 Mark42 is offline
Default Bayliner project updated.
For those of you who don't frequent the boat building forum, I have updated the hard top project for my Bayliner. Check it out by clicking the link in my signature below.
Comments are welcome!
Thanks
Mark
__________________
1985 Bayliner 1600 Capri Cuddy, 1965 MFG Niagara Custom. >> MFG Video<<. >> MFG Project<< >>Bayliner Hard Top Project<< >>Bayliner Fuel Tank Project<<
  #2
Old June 17th, 2008, 11:09 PM
azlakes's Avatar
azlakes azlakes is offline
Default Re: Bayliner project updated.
....looking good Mark, glad your back to working on it! still thinking of going down to bilge level or there abouts eh? heard of a new ply out called OSB Oriented Strand Board. suppose to have anti rot and watershed properties added in. may be worth a look see.
__________________
86' Capri 1950 BR
Force 125hp
Desert Southwest
  #3
Old June 30th, 2008, 09:06 PM
Mark42's Avatar
Yes, I'm still planning on lowering the floor to bilge level. If I drop the floor to the bottom of the stringers, that will still leave a two to three inch deep bilge area (due to the V shapped keel) and give me an additional 5" headroom. The area between the seat bases, and the length of the seat bases, would be affected. Thats about a 23 x 30" area. The deck in front of and behind the seat bases would remain stock height. So once you enter the boat from the swim platform, it would be one 5" step down as you walk under the hard top roof. The extra headroom is not needed for my 5'8" height or my wife at 5' 1". But my brother will appreciate it, he's about 6'.
I'm also playing around with a new seat design. Remove the two back to back lounge seats and replace with a bench seat that will hold three on the port side, and two swivel captians chairs on the starboard side. That should maximize seating in the cockpit. I don't need lounge seats with the cabin, and having a small bench seat makes more sense for my use. Like I said, I'm still playing around with the design.
The cabin folding door will probably get tossed because its heavy and not very attractive. Will replace with a tinted plexy door. The cabin wall under the helm will probably be replaced with tinted plexy also. There will be a single center post for the cabin door to close against, a single diagonal brace on the starboard side, and one or two toe holds on the center post to make climbing up/out the opening port windshield easy.
I'm leaning towards making the starboard windshield non-opening. This is for a few reasons. 1) its easier to have a windshield wiper on a window that does not open. 2) A non-opening windshield will add more rigidity to the top. 3) the windshield windows are big - about 24"x30" and hardware to support and manage the opening windshield is expensive. 4) the side windows will slide open, so there is plenty of ventilation available.
__________________
  #4
Old July 29th, 2008, 10:16 PM
kingsurvey kingsurvey is offline
I'm in the process of buying a 1970 19' Bayliner 70 hp Evinrude boat--- 1980 + engine. After reading the comments on construction I wonder if it goes all the way back to 1970. The 19'er was used for fishing off the coast of Norther Calif, and the San Francisco Bay and there isn't a jel coat crack ---- none. This would lead me to believe that there very early boats were sound --- very.
Can you support this view?
Thanks
R. King
  #5
Old July 29th, 2008, 10:46 PM
Mark42's Avatar
From all the boat restoration posts/projects I have read about on these forums, it does seem that the vast majority of boats with rot, poorly glassed stringers, floor and transom, are all in the late 1980's models when Brunswick bought Bayliner. They started cutting quality to make a lower priced boat.
I know that my 1985 fiberglass work in the bilge, floor and transom compared to some 1989 models is much better. There is no bare wood exposed in those areas in my boat.
The boat has some lower priced materials compared to more expensive boats. The ceiling of the cuddy is covered with carpet, where Searay uses vinyl. The marine grade vinyl in the seats is not as thick as other boats I've seen. But little things surprise me like stanless steel hardware, screws, latches, hinges, etc.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
updated project pics Reinellchris Boat Restoration and Building 9 September 10th, 2007 03:06 PM
out of project boats, is this crazy? Updated 12/6 tashasdaddy Boat Restoration and Building 14 December 9th, 2006 12:14 AM
Updated Project Photos - It's done Terry Olson Boat Restoration and Building 6 October 8th, 2006 01:30 AM
1964 Atlas Floor Project - Updated w/ Pics (6/16/06) bucks17 Boat Restoration and Building 10 July 1st, 2006 11:58 PM
Pics of yet another project (updated) deputydawg Dockside Chat 15 January 14th, 2006 05:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
