The mechanism you move with your hand to adjust the throttle is fairly tight on my boat. When I give throttle it is not so bad, but when I am de-throttling, when I get to 1/4 thottle it almost feels like the thottle is stuck. I have to use a lot of pressure at the 1/4 throttle point to get to idel/neutral.
Is there any general maintanence stuff I should be doing to make the throttle smoother and not so tight?
Thanks
Thanks
