  #1
Old June 17th, 2008, 03:22 PM
Baiteater Baiteater is offline
Default Suggestions for mounting GPS onto center console
Hi all,
I'm new to the forum and have done some extensive searching of previous posts for a solution to my problem but having found nothing specifically applicable I'm making my first post now.
I just had the center console of my 1999 Hewes Redfisher 18 refinished to fill and cover several holes that were made to accomodate a CD player, speakers, an a VHF mount and I'm thrilled with the results. However, now I need to remount my Garmin GPS 168 Sounder onto the top of the console. It mounts on a standard bracket using 4 screws. However, in the past I just ran the electrical cable (attached to the power source, ground and transducer) through a hole in the top of the console adjacent to the mounting bracket because the console had too many other places for water to intrude for me to bother sealing this one hole. Now my console is truly water tight and I want to install the GPS and bracket in a fashion that will maintain that integrity.
My question is this: How would you recommend that I seal the hole that will be necessary for me to drill to allow the cable to pass through the top of the console from the power source below. It must be about 1/2" in diameter to allow the largest part of the transducer cable to pass through, however once the coaxial connection is through there will be only two cables of considerably less diameter than the 1/2" left in the hole. I need to seal that hole with some compound that will be water tight as well as look good against my brand new console. I've considered MarineTex, clear or white silicon, 3M 4200 or 5200. I suppose it should be somewhat flexible because the cables could be under some lateral pressure at times and the cables will flex when I remove the unit for security reasons.
I've considered drilling right through the bracket (I have access to a drill press that might make it easier to do so without breaking the bracket) in order to make the lines of the unit look a bit cleaner and the black color would be easier to mask any sealant I end up using. Ideas?
Lastly, what type of sealant is used to seal around switch plates, steering consoles, hatch covers, etc? It's black with a dull finish and seems to me that it blends easier with the edges of black items on the console like switch plates and the base of the steering column. Is it that stuff I see at the marine store in the black and yellow package...marine lite, marine tite? Am i barking up the wrong tree here or what?
Thanks to all who respond and for hosting a very informative forum.
  #2
Old June 17th, 2008, 03:27 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Suggestions for mounting GPS onto center console
they make electrical grommets to seal the wire.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old June 17th, 2008, 03:40 PM
tommays's Avatar
tommays tommays is offline
Clam shells make a nice cover that allows sevice in the future
__________________
If a dirty bottom slows you down what do think it does to your BOAT
Tommays
  #4
Old June 17th, 2008, 07:00 PM
dingbat's Avatar
dingbat dingbat is offline
Sounds like you need a cable clam
http://www.google.com/search?q=cable...e7&rlz=1I7ADBF
__________________
Grady White Seafarer
200 Evinrude Ocean Pro
  #5
Old June 17th, 2008, 09:28 PM
I don't think the clam shells will work as the surface I'll be drilling is horizontal and they would clearly leak. The cable clam looks interesting, though. I'm not sure that I could get a grommet over the coaxial end piece however. Thanks for the tips.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Center console v dual console Kachadurian Boat Topics and Questions (not engine topics) 14 December 22nd, 2007 08:13 PM
GPS - "Perfect for vertical console mounting...???? BBogey Electrics, Electronics and Trolling Motors 0 February 4th, 2007 02:08 AM
New Boat: Center Console , Walkaround, or Dual Console PAkev Boat Topics and Questions (not engine topics) 17 April 2nd, 2006 08:14 AM
Center console FISHERJEEP Boat Restoration and Building 4 June 30th, 2005 11:45 AM
Center Console Scott-14 Boat Topics and Questions (not engine topics) 6 October 15th, 2003 03:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
