  #1
Old June 17th, 2008, 01:11 PM
Waterskipper Waterskipper is offline
Default Transom replacement Starcraft Aluminum
Hi everybody,
I have a 1976 Starcraft 19' Aluminum open bow with a 90 hp Chrysler ob. I've had this boat for about 10 years...it has spent the last 4 in the garage. Anyway, I pulled it out this spring to do 'something' with it. (either use it or sell it) I picked the Motor up a bit by hand and noticed much more movement in the transom than I wanted to see. I removed the transom core and now wonder how the 90 hp Chrysler stayed in place to begin with. I have read on some of the forums some people are in favor of replacing the transom using a marine grade plywood, others say you do not really need to use marine grade but use a birch plywood and coat it with a 2 part epoxy resin. I will be using the craft primarily on smaller lakes in upstate NY. The boat does not stay in the water for more than a week at a time per year. Other times we would use it for a day and retreive it again. My concern is, will this waterproofing resin protect the plywood enough for going without the marine plywood. This is the first time I have tackled such a project, it doesn't seem to be hard, just time consuming. Experienced advice would be greatly appreciated.
  #2
Old June 17th, 2008, 01:56 PM
ezmobee's Avatar
ezmobee ezmobee is offline
Send a message via MSN to ezmobee
Default Re: Transom replacement Starcraft Aluminum
Doing mine right now. As you said, not difficult but definitely taking a lot longer than I thought to get everything back together again. Exterior ply coated with resin is the recommended method on here. Also you should pre-drill and over drill all your holes so you can coat the insides of them well with epoxy. Done like that it should far outlast the original
__________________
1976 18' Starcraft SuperSport 90HP Evinrude
Restoration thread http://forums.iboats.com/showthread.php?t=357767
1966 16' Starcraft Jupiter 85HP Johnson
Restoration thread http://forums.iboats.com/showthread.php?t=338633 sold
  #3
Old June 18th, 2008, 01:04 AM
MaxOD MaxOD is offline
I used a treated plywood on my 16ft Starcraft. It was a heavier grade though with more layers laminated. Was very strong and will last forever.
  #4
Old June 18th, 2008, 06:37 AM
Question Re: Transom replacement Starcraft Aluminum
Quote:
I thought about using pressure treated also as an alternative to marine but was told there could be a corrosive reaction between the aluminum and the pressure treated wood. Have you found this to be true?
  #5
Old June 18th, 2008, 08:09 PM
Nandy's Avatar
Nandy Nandy is offline
Quote:
Waterskipper, you have the correct information. If you can isolate the metal from the treated wood by the use of nylon washers then you would be ok. Stay with marine plywood or regular plywood.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Decking replacement - 16' starcraft aluminum v-hull supr78nova Boat Restoration and Building 2 June 1st, 2008 09:04 AM
Aluminum Gamefisher transom replacement ejm Boat Restoration and Building 1 May 4th, 2008 08:32 PM
Aluminum boat transom replacement ezmobee Boat Restoration and Building 9 April 17th, 2008 07:38 AM
Aluminum Starcraft transom repair? KilroyJC Boat Restoration and Building 39 August 15th, 2006 08:51 AM
82 StarCraft Transom Replacement mjash Boat Restoration and Building 1 May 29th, 2006 02:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
