I have a 1981 johnson 140 v4 with power trim/tilt. I have recently replaced seals on one of the lower rams. The unit was working proplery prior to the seal replacement...just leaking at the seal. I am not sure whether i can't seem to get the air out or what, but the unit lifts until the lower rams are extended and then it will not lift on the main tilt. with just a little hand help it will raise and it will hold in the up position without falling. It lowers with no problem. Any suggestions....maybe bleeding air procedure??
thanks
thanks
