  #1
Old June 16th, 2008, 08:07 PM
gordon1 gordon1 is offline
Default 40 hp evinrude lark selectric shift
my tranny shifts ok but it seems to be slipping in foward gear.full throttle it barely is moving.someone had 90 weight in it,i put c type in it,hould this cure it?i just bought boat and discovered that 90 weight was in tranny when i bega
n trouble shooting.i have had all apart and cleaned cluthes before adding c type oil,should this cure the problem?also,it is engaging in foward and reverse.
  #2
Old June 16th, 2008, 08:29 PM
F_R F_R is offline
Default Re: 40 hp evinrude lark selectric shift
The 90 could have damaged the clutch. Before jumping to any conclusions, check the voltage at the green (fwd) and blue (rev) wires where they go down to the lower unit. Check them without disconnecting them. You need full battery voltage. A bad shift switch can deliver reduced or no voltage, causing slipping or no shift.
Don't forget that it could be the prop hub slipping and not the clutch. So check that too.
  #3
Evinrude Boater's Avatar
Evinrude Boater Evinrude Boater is offline
Master Chief Petty Officer
Maybe the rubber hub in your prop is failing. Take it off and draw a line across the prop and hub, run it and then see if the lines are misaligned from the hub spinning.
  #4
Old June 16th, 2008, 09:46 PM
the cluthes and springs look ok.I did check prop already for a spun hub,its ok.i need to check voltage to wires,that could be it!|
  #5
Old June 16th, 2008, 10:06 PM
R.Johnson R.Johnson is offline
My experience has been, once that spring, and hub has slipped, they are usually done. I have tried different methods to restore them, but none with any success. You could try jumping the shift wire to the hot side of the starter solinoid, but first take a reading on the electro-magnet. It should be 8 ohms.
  #6
Old September 2nd, 2008, 10:04 PM
11steveo 11steveo is offline
having similar problems as last gentleman, reading 8 ohms on back magnet but very litlle on forward. Can this be fixed? what causes an electric magnet to loose ohms.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1971 50 HP Evinrude Selectric Shift. w2much Johnson & Evinrude Outboards 5 January 8th, 2006 02:43 PM
Evinrude 65 hp "Selectric Shift" no neutral stingray2232 Johnson & Evinrude Outboards 3 May 30th, 2005 06:56 PM
Evinrude Lark4 w/selectric shift PSCinMaine Johnson & Evinrude Outboards 1 June 16th, 2004 06:29 PM
Evinrude Lark 40 Selectric rhhauck Johnson & Evinrude Outboards 1 July 5th, 2002 02:15 PM
1969 Evinrude 40 hp, Selectric shifter...won't sharonhead Johnson & Evinrude Outboards 1 May 17th, 2002 08:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
