I'm replacing number 3 piston I'm sure you have to pull off the intake manifold this is a L drive motor I see all the small bolts around the sides and the 6 9/16 bolts that need to come off are there two bolts on the bottom of the manifold and does the flywheel have to come off. any help will be appreciated.
