I have a friend that has this motor installed in a river boat, it is installed as an inboard what is it an out board installed as an inboard? Serial# OE428143
would this be a 175 optimax it is a 2 stroke. Thanks for your time
This motor has Mercury jet drive 175 XR2 on the air cleaner it is a 6 cylinder oil injected 2 stroke manufactured in 2005. I was told that this might be an outboard converted to an inboard, just to satisfy my curiosity I would like to know what it is, might be a special for jet boats. Thanks again.
It is a hybrid, basically the outboard powerhead mounted on a jet pump. Merc's been doing this starting by using the force powerheads on SportJets in the early 90's.
No, the original SJ's were derived from Force powerheads-the 90's & 120's.
I have the 175xr2 shop manual on pdf-I'll put it on a file sharing site so you guys can dl it. Its early, Powerhead serial #'s starting at OE203000...not sure if I can dig up a later version with any ignition mods. If not this should help-very thorough.
