Hey guy thanks in advance for any help you can give.
What i have is 1984 inline 6 merc 115. Did not runworth 2 hoots. Ran compression test 120 psi all cylinders. Next checked for spark good spark all 6 installed new plugs. Pulled carbs did a full cleaning and rebuilding new needles and seats and a new fuel pump also checked reeds while carbs were off. Did the sync on timming and carbs. go to the lake idles beautifully, but as you throttle up when the timing advance hits its stop it just laid down. So broke out timing light and when at full advance 2,4,6 cylinders loose spark. Thought must be bad timing ring, picked up new one and installed still does same thing. what gives.
thanks no hair left Rob
