Got a little problem here guys, cant seem to figure it out. I was out fishing yesterday, trolling for a while. After killing the motor to drift over a nice little hump i went to restart the motor to head back up over the spot and nothing happened when i turned the key. I eventually got towed back in by a friend and today after some diagnosis it seemed like the issue was with the solenoid. after replacing this, the problem persisted....still nothing happened when i turne the key. turns out the in line fuse that comes off the solenoid was blown. after it was replaced the motor started again...i turned it on and off a few times and everything seemed ok. went back out fishing...but the fuse blew again...i replaced it on the water and headed back in....since then i've started and killed the motor repeatedly on the muffs without a problem....maybe its happenening when i open the throttle up some. i went through everything and couldn't find a short or anything in any of the wires so i'm really lost...i'd hate to go back out and have this happen again....do any of you know what this could be.....the motor is an 87 evinrude 50 vro....
thanks for any input in advance....
