jacobpourciau
- Feb 21, 2008
- 38
Today i was fishing a HEAVY area with nothing but weeds/duckseed. The water is high so It was all in the canals. Well my pee hole STOP peeing. The funny thing is that i could tilt my engine all the way up then set it back down and it would pee agian (unexpalinable?).....Well after doing this twice tilting it up didnt work anymore so i had to get towed back to the landing. Well on the way home i stopped and picked up an empellor thinking that was the issue. Get home and drop lower unit (1st time doing this operation). Replace the empeller the install L/U. Well what was wierd when i started the engine it would not go into forward gear when pushed lever forward. I made sure to count on my shift rod how many threads were exposed that way i could install it back properly. After messing with it for a little while, the only way it would shift right is if i had 10 threads showing instead of nine like it was originaly. What would cause this, and also it seems to shift fine with 10 threads exposed on muffs. When i say threads exposed i mean the nut that disconnects the shift rod from lower unit. So is it ok for me to have it like it is???? Also what arte some things i can do to try and dislodge any duckweed that could still be left in my engine?? Thanks!!
