  #1
Old June 13th, 2008, 09:38 PM
Den H Den H is offline
Default 90 hp mercury 3cyl. 2 stroke slow to get on plane
I have a 1987 Mercury 90hp 3cyl. 2 stroke that idles good and runs great once the boat gets on plane all the way up to max rpm which is 5500. The motor seems to be down on power off idle to about 3000 rpm. The boat is a 1987 Cheetha bass boat 15.5ft. I have checked the timing it is set at factory specs. Where is the idle air screw? My parts list shows the adjusting screw on the side of the carbs that is beside the jet vent is called the idle needle screw and the adjusting screw on the top of the carbs by the intake is called the idle air needle screw. Which one does what? Also would adjusting one of these help? Thanks for any help.
  #2
Old June 14th, 2008, 12:42 AM
mikeregas mikeregas is offline
Default Re: 90 hp mercury 3cyl. 2 stroke slow to get on plane
I am having the same problem with my 98 mariner if you get any info on where or what to do let me know I would love to get my boat up on plane like it use to. I have a 16' Action Craft flats boat and it use to really jump up on plane now it drags and drags then it finally gets up on plane. I have been using my trim tabs to get on plane faster, which helps. Once it get on plane it seems to do ok.
  #3
Old November 14th, 2009, 10:43 AM
arcrat arcrat is offline
Do not mess with screw on top... it is factory set!!!!
Try adj side screws out 1/8 turn....
Top screw is air ...
side screw is fuel...
someone sould jump in and help out , give it some time ...
arcrat
  #4
Old November 14th, 2009, 05:38 PM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
What are the comp readings and when was the last time the carbs had an overhaul?
__________________
Watch this space......................
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
MERCURY SPORT JET 90 HP TOO SLOW RICHRICH26 Mercury & Mariner Outboards 30 June 24th, 2009 12:36 PM
Mercury XR2 slow to plane out jds520 Mercury & Mariner Outboards 2 February 25th, 2008 08:28 PM
1990 175 HP Johnson Loss of Power/Slow to Plane imported_Z Johnson & Evinrude Outboards 15 December 2nd, 2006 05:57 PM
2000 Mercury 90 HP 4 stroke! mako Mercury & Mariner Outboards 3 July 3rd, 2001 07:28 PM
mercury 4 stroke 90 HP 2 lemons? bad4stroke Mercury & Mariner Outboards 0 July 3rd, 2001 06:54 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
