  #1
Old June 13th, 2008, 06:28 PM
K Hultgre K Hultgre is offline
Default Lower Unit for 1965 Evinrude 18HP
I just acquired a Evinrude 18hp with a bad forward gear and clutch dog. The previous owner pulled it apart so I am also missing the pinion gear thrust bearing and both forward and reverse thrust bearings.
I only have 2 questions to start with.....
What other model year and horse power Evinrudes have the same lower unit, or one that will bolt up or use the same internal parts?
Can anyone direct me to a used part house that I could try other than TC outboard?
Thanks
Kevin
  #2
Old June 13th, 2008, 06:59 PM
F_R F_R is online now
Default Re: Lower Unit for 1965 Evinrude 18HP
That basic lower unit was used for many years, from about 1955, up into the '80s, on the 18-20-25hp 22 cu in motors. That's not to guarantee that all the internal parts are the same. Looking up the part numbers will verify yes or no.
  #3
Old June 13th, 2008, 10:29 PM
OMC web site only goes back to 1968. Do you know of a web site that shows prior to 1968 Evinrude/Johnson diagrams and part numbers?
  #4
Old June 13th, 2008, 11:01 PM
I can tell you this: I just checked the books for the '63 and '68 and they are the same, so your '65 surely would also be the same as the '68. Same that is except for they did an un-nose job on the case somewhere in those years (straightened the leading edge), but that makes no significant difference.
Then I went back to '59 and found some different part numbers for the gears. But I'm confident that the whole thing as a complete unit would bolt up and work.
  #5
Old June 14th, 2008, 09:50 AM
rjezuit rjezuit is offline
Try laingsoutboards.com. Rick
  #6
Old June 14th, 2008, 10:17 AM
I am looking at a gear set that the seller states has the following numbers -
#s found on 387209, 320800, & on the cradle looks like 303731
Could you please check and see if they will work? all help is much appreciated.
  #7
Old June 14th, 2008, 10:31 AM
ezeke ezeke is offline
Expanded list:
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
americanoutboard.com
garysmarine.com
sea-way.com
  #8
Old June 14th, 2008, 11:43 AM
Sorry, I have nothing crossing to those numbers. BTW, 303731 is a reed stop, not a cradle
  #9
Old June 14th, 2008, 06:07 PM
And 387209 is a forward gear from a late 1970's 6HP motor. Checking 320800, that's late 70's 6HP as well, but reverse gear.
  #10
Old June 17th, 2008, 02:29 PM
Thanks for the great help, I'm sure I'll be back with more questions before this one is done.
  #11
Old July 3rd, 2008, 11:24 AM
Can anyone tell me if the lower unit complete and or gear set from a Evinrude Fasttwin 15hp model 15012 will fit the 65' 18hp ?
  #12
Old July 3rd, 2008, 12:01 PM
R.Johnson R.Johnson is online now
One easy way to tell is if the case has a 5 bolt pattern such as your case has. F R pointed out the difference in the 20, 25 HP case, another difference is that the 25 case is much thicker in cross section, making for a much stronger casting. One thing to look out for when changing the case is to check, and see if it is bent, I found this to be quite a common problem wwith the 15, and 18 case, as they are quite thin through the lower web. This will cause undo strain on the drive shaft, and lower pinion gear bushing. With the case apart, you can set it up on a flat surface such as a drill press table with a pointer, or dial indicator in the chuck. With the case upside down on the table, you measure to see if the two surface's are parallel. The maximum tolerance is .030. We once bent the case on our 18. I measured 3, or 4 cases' before I found one in tolerance, none were truly straight. We have 2 l8 HP engines, I put 25 cases' on both. Our local river can be very shallow, that is it can be until a couple of week's ago, when it went 12 ft. above the all time record 40 miles down stream from us. It can give a engine quite a beating if you are not careful.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1965 40HP Evinrude Big Twin lower unit cz1234 Johnson & Evinrude Outboards 3 March 30th, 2005 07:40 AM
1965 Evinrude lower unit onto 1962 Johnson? merc_500 Johnson & Evinrude Outboards 2 July 29th, 2004 08:34 PM
1965 Evinrude 90hp lower unit parts ???? ldrumond Johnson & Evinrude Outboards 3 July 25th, 2004 03:26 PM
1967 Evinrude 18hp hole in lower unit? mulv80 Johnson & Evinrude Outboards 2 April 30th, 2004 06:04 AM
18hp Evinrude lower unit... Wraith Johnson & Evinrude Outboards 4 June 14th, 2003 07:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
