  #1
Old June 13th, 2008, 04:47 PM
danrs danrs is offline
Default Buying question? Engine replacment in new boat, concern?
This is not specifically an engine question, but an overall boat condition question, so hope it's okay to go here.
On a 8 to 10 year old boat, is an engine replacement a good thing or bad thing? I guess I'm kind of equating it to a used car in my mind...I think a "engine replaced" or "engine rebuilt" or "transmission rebuilt" is not necessarily a good thing. If the engine had that many hours on it or was maintained so poorly on a 8 year old boat (or car), then that has got to have carried over into the rest of the boat (vehicle), no? And it always seems whenever something that major is replaced, it never quite goes in as well, or performs as well as the original new item.
I guess when I see that coupled with a pretty low for year price, it gets me worried. Should it? Or are engine replacements a common enough thing that it is not to be of concern?
  #2
Old June 13th, 2008, 05:04 PM
tmh tmh is offline
Default Re: Buying question? Engine replacment in new boat, concern?
Depends.....give specific info on which engine came out and which went in for more help, but....
Sometimes and otherwise well cared for boat can have a mistake made winterizing it - the block cracks and next season the owner re-powers. Now, what does "repower" mean in this case? Did they buy a NEW engine or just a block? WHY did they need to replace the engine????? Did they upgrade the power while tey were at it? How long ago - don't want one if they repowered just to sell because maybe corners were cut to save $$$.
Do they have all receipts of the repower so you can know what was done exactly? If not, hmmmmmmm.....
You can look at the rest of the boat and get an idea if it was cared for. Have a mechanic YOU pick go through the engine and drive for sure before buying. I'd have no problem buying a repowered boat if all else checked out.
  #3
Old June 13th, 2008, 05:46 PM
Nandy's Avatar
Nandy Nandy is offline
tmh has real good points. If I look at the boat and it is in great condition then I would feel better about the repower as proably this is a boater that took care of his boat. Added to that, if I can see a receipt that shows a competitive price on the motor repair and the reason the motor failed you know they fixed it right or at least they were not trying to cut corners and why it failed. If the owner dont have a receipt but the repower was done and he used it for a few seasons that would also lead me to believe the work was done properly. In reality, there is not a way to tell for sure either way...
  #4
Old June 13th, 2008, 05:48 PM
MikDee's Avatar
MikDee MikDee is offline
Pretty much what tmh says, but also, did they do the right thing, and replace the engine coupler with a new one also? This is like the flywheel, & torque converter on your car,(only it has large rubber hub inside, that dries out, and possibly slips after a number of yrs) all the power is transferred through it, And you have to take the engine out to get to it. The engine, & coupler are 1st concern, the drive is a 2nd concern, because at least you can get to it, & remove, and or, replace it fairly easily.
__________________
89'-19' Bayliner Capri Ski boat, with a 125hp Force
My Previous Boats http://smg.photobucket.com/albums/v2...ee/My%20Boats/
My motto - Keep It Simple Stupid
  #5
Old June 13th, 2008, 05:56 PM
dingbat's Avatar
dingbat dingbat is offline
In my circles (SW) repowers are pretty common place and are looked upon as good things.
We typically put a ton of hours on motor in a season so it's not uncommon to need new power from time to time. Not to mention that fuel efficiencies have increased significantly in the last several years which makes new power very attractive now that fuel is over $4 a gallon.
I know of quite a few people that took perfectly good motors off their transoms and replaced them with more fuel efficient motors as cost savings measures.
__________________
Grady White Seafarer
200 Evinrude Ocean Pro
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Buying A New Boat for Salt/Freshwater fishing - Lots of Question Hennessey Boat Topics and Questions (not engine topics) 1 February 14th, 2008 04:32 PM
buying a new boat ????? curtisimo1981 Boat Topics and Questions (not engine topics) 8 April 27th, 2007 09:59 AM
Concern: Buying 2004 I/O in salt water 1 season sail&power Mercury & Mariner Outboards 3 February 15th, 2006 05:49 AM
Buying New Boat.. Help with Engine Selection/Type... TheChad Non-Repair Outboard Discussions 14 July 2nd, 2005 06:25 PM
Dumb question on buying a used boat and engine life Sharps-Nut Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 14 September 8th, 2004 12:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
