I very strongly recommend an OEM workshop manual or you will probably have difficulties.
If you insist on doing it without a manual (as I probably would!) you will find the exploded diagrams on the BRP parts website useful.
See here
Note in particular that the seals on the prop shaft and on the drive shaft go back to back as shown on the diagram.
You will need to remove the prop and the drive shaft.
You will also replace the water pump impeller wont you! You'll need the water pimp kit as well. Watch out for the key!
I guess you will also repace the anodes so you will need an anode kit
For a complete dummy allow a lot more than a couple of hours.
