elderhappy
- May 15, 2008
- 3
I have a 9.5, dumster dive. I got it to run with a minimum of work last year, new points and condenser, water pump, lower unit seals.
it would not idle for long periods of time, it starts to slow down then misfires and dies. if i give it full throttle right away it starts right up, otherwise i need to go through the chock process.
I decided to change out the coils, wires, plugs this year. I also pulled the head and cleane out some carbon, replaced the gasket. the clyinders are and even 70 psi at 4 to five pulls cold. it now has a full time miss. when i pull the top cylinder wire it dies, when i pull the bottom cylinder wire it runs smoother.
any ideas what i did to it.
