Guys,
I tested my lower unit with a foot bicycle pump and connected it to the lower unit using plastic oil pump hosing. The only leak was at the plastic oil pump hosing. I'm concerned that it only lasted about 20 seconds to leak air out the plastic hosing. Should try something different to keep pressure for longer. Like I said at about 12 lbs the only leak was at the plastic hosing when submerged in water.
