  #1
Old June 11th, 2008, 11:05 PM
fishdog4449's Avatar
fishdog4449 fishdog4449 is offline
Default mercury 1150 flywheel bolts thread pattern?
Anyone know the thread pattern for the eight bolts clustered around the inner part of the flywheel? (1974 Mercury 1150)
Thanks!
__________________
1972 Macgregor 25'
1981 Glassmaster 17 '76 Mercury 1150 tower of power
  #2
Old June 11th, 2008, 11:50 PM
emckelvy emckelvy is offline
Default Re: mercury 1150 flywheel bolts thread pattern?
Thread pattern (??), do you mean torquing sequence??
If so, just snug all the bolts down; tighten one bolt then the bolt opposite the one you just tightened. Work around the flywheel until all bolts are tight.
Bolts should be torqued to 25-foot/lbs.
Prior to installation, degrease the bolts and apply one drop of Loctite Red threadlocking compound to each.
BTW these bolts are 5/16"-NF, Grade 8 if I recall.
HTH.........ed
  #3
Old June 12th, 2008, 12:20 AM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
Yup..... I believe that's correct 5/16-24 fine thread.
p.s. Don't forget to mark the flywheel orientation if you are planning to remove them all. The timing indicator is set up based on its current position.
If you're planning just to remove three bolts to install a puller then that's not an issue. They do make pullers that thread into the inside as well. Available on eBay relatively cheap, and they double as a lifting ring.
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
  #4
Old June 12th, 2008, 10:01 AM
thanks guys! I just needed the info on the bolts b/c im lifting the motor by installing eyes in two of the holes and needed to know the threads for buying the eyes.
__________________
1972 Macgregor 25'
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
My BIG Thank You thread - 1970 Merc 1150 IL6 VVVLP+Pics MercFan Mercury & Mariner Outboards 4 October 11th, 2007 03:15 PM
Transom mounting bolts spacing/pattern DF140 Wilhelmsen Yamaha & Suzuki Outboards 2 September 19th, 2007 05:22 AM
Thread Chaser for Head Bolts jdtower23 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 July 1st, 2007 09:47 PM
1150 trim pump thread spargs Mercury & Mariner Outboards 6 February 3rd, 2006 01:37 AM
Pulling flywheel, need thread sizes ILDUCKHUNTER Johnson & Evinrude Outboards 4 June 12th, 2002 07:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
