Good day all,
today i took my little v bottom to a pond that i fish in. At first, the boat was planing and running perfect, and then i took it through a little patch of moss and it was not so good.
The motor was running fine, but when i would give it some gas to plane out it would act as if the prop was spinning, but not catching completely. It was almost as if it was kind of slipping. I took it home and took the prop off so that i could insptect the pin. The pin was in perfect condition. It was not bent, cracked, broken in any way.
Is there something else that i should check at this point i don't know what else to look for.
Thanks, James
Thanks, James
