galen_spradley
- May 12, 2008
- 3
i have a 1979 mercury 4.5hp motor w/ serial # 5271459
upon takin the foot off and checking the water pump and checking the impeller inside i found out that the impeller was eatin to pieces.. i went out and bought a new impeller and replaced it right and still no water pumps out... i took the foot of again .. a total of 6 times and checked to make sure the impeller was turning the right way but no water comes out up top ... just hot exaust.. is there a oring that goes in there on top of the impeller that keeps air from suckin inside the water pump base and top? cause i saw a pic of a impeller kit and it had both impeller and oring and impeller plate .. my plate was good so i didn't replace it.. should i have? cause no oring was in there when i took it apart.. would a oring being missing cause it not to pump water up into the engine and out the spout?..........somebody please help me with this problem
