June 10th, 2008, 12:03 PM
blown head gasket yet no water on spark plug? 1992 Evinrude 90 VRO
I am wondering if this is possible? Also, could a leaking head gasket only affect the compression on one cylinder?
115 lbs on 3 of 4 cyclinders -- went from 80 to 85 lbs on the bad cylinder after a decarb on muffs.
waiting on gasket and manual to be delivered before I pull the head....might do another decarb in the meantime.
Thanks,
scmutiger
June 10th, 2008, 12:30 PM
Re: blown head gasket yet no water on spark plug? 1992 Evinrude 90 VRO
head gasket does not always blow into water passage. yes it can effect only one cylinder.
__________________
FLORIDA GATORS
TEBOW Country
See you at the
2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
June 10th, 2008, 12:33 PM
Remove the cylinder head now so that you can relate to us what you find. You'll need to remove it anyhow.
June 10th, 2008, 01:33 PM
As the above 2 posts. Gasket can blow anywhere, not necessarily just the waterways. It will still lose compression and yes it can only affect the 1 cylinder. It will only get worse the more you try and use it.
Lets get the head off and see what is going on.
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
June 10th, 2008, 02:06 PM
Thanks to everyone that replied. I will get the head off this weekend and post back with some pics....
Thread Tools
Search this Thread
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
