  #1
Old June 10th, 2008, 12:01 PM
crabshaw crabshaw is offline
Default Water pump on a 1996 150hp mariner
Is it difficult to change the wp on this outboard? I was a mech for a lot of years but never worked on a outboard.
  #2
Old June 10th, 2008, 12:10 PM
Chris1956 Chris1956 is offline
Default Re: Water pump on a 1996 150hp mariner
It is not a difficult procedure. It is best to get a manual and read up first. No special tools are required, and you will likely need to replace only gaskets, orings and the impeller and Stainless Steel base plate
  #3
Old June 10th, 2008, 03:03 PM
gss036 gss036 is offline
Do a search here, there are several threads that deal w/it and some w/links to pages that will tell or show the procedure. As Chris said, realitive simple procedure. Make sure you get all the visible bolts and then one under the trim tab. You have to remove the trim tab thru the hole on top, it usually has a plastic cap on it. Use an extention w/locking type release otherwise you may just end up leaving the socket in the hole.
  #4
Old June 10th, 2008, 09:21 PM
Thanks for the info I will give it a try.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 150hp Johnson Oceanrunner Water Pump Replacement darrisc Johnson & Evinrude Outboards 1 June 2nd, 2008 01:52 PM
1996 mariner 60- water pump question bitzer26 Mercury & Mariner Outboards 4 May 28th, 2008 08:46 PM
Cleaning water passages on 1996 150hp ocean runner swade28 Johnson & Evinrude Outboards 5 June 14th, 2006 02:09 PM
1996 Mariner 150HP Overcharging Batt 16.5Volts thewatercallsme Mercury & Mariner Outboards 7 February 23rd, 2005 12:59 PM
Oil pump failure on 1996 Merc xr6 150hp NITRO25 Mercury & Mariner Outboards 11 August 16th, 2002 07:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
