  #1
Old June 10th, 2008, 03:07 AM
HotLZ HotLZ is offline
Default 1999 Yamaha 150 OX66 won't charge battery - Help Please-
Had this motor on a used Skeeter I bought a couple years ago, and I've been battling battery/charging troubles non-stop since I've owned it. Basically the battery won't charge. We've put a new stator in, tried a two battery system, diff. batteries, and just recently put in a new rectifier. I thought we finally had the problem fixed after putting in the new rectifier, because the output on the motor went from a max of about 12.6v to a little over 14 when I tested it in the driveway, but after a day on the water, the battery gradually wound down, and eventually went dead. Tested it again on the water, and it was only charging to a little over 12 again. Huh??? Anyway, brought it home, charged the battery, and tested it again in the driveway today. It was charging at a little over 14 again. I don't get it. Any clues on what to check or look for? Thanks much.
  #2
Old June 10th, 2008, 08:45 AM
rodbolt rodbolt is offline
Default Re: 1999 Yamaha 150 OX66 won't charge battery - Help Please-
carefully test the stator output, the specs are in the tune up guide and the service manual, if stator output is ok the test the rectifier output.
if you have loose battery cables(wing nuts) or a bad cable it will burn a new rectifier.
I try not to replace any component unless my test equipment shows its failed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999 Yamaha OX66 Propellers jfbetz Prop Questions and Topics 2 March 5th, 2008 08:40 AM
yamaha 1999 200 ox66 geckoman7783 Yamaha & Suzuki Outboards 7 May 21st, 2007 10:37 PM
1999 yamaha ox66 200 geckoman7783 Yamaha & Suzuki Outboards 8 March 5th, 2007 10:02 PM
Yamaha OX66 does not charge battery Wiscbw Yamaha & Suzuki Outboards 1 April 17th, 2006 04:48 AM
1999 ox66 yamaha 200 teaker16 Yamaha & Suzuki Outboards 4 April 6th, 2006 04:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
