  #1
Old June 10th, 2008, 01:21 AM
piggy piggy is offline
Default Question on trolling motor for pontoon
Thinking of putting a 55 lbs. thrust trolling motor on a 20 ft. pontoon as a back-up. years ago I had a 55# thrust on a 24 ft. But I only used it one time and I don't remember how fast it was. It would be used in some current (about 3 m.p.h.) Would this work, about what kind of speed could I expect(no current). Going wide open about how much time would it take for 55 lbs. trolling motor to drain a 12 volt deep cell battery. I know this is hard to answer, just a best guess please. Thanks for any advice
  #2
Old June 10th, 2008, 01:49 AM
DavidD DavidD is offline
Default Re: Question on trolling motor for pontoon
I just added a minnkota 55lb to my 24' pontoon.It pulled it very well even with the bimini up and the wind blowing.Not sure of the speed wide open but it moved
fairly quickly.I run several hrs on 1 of my deep cycles and still had battery left.
  #3
Old June 10th, 2008, 09:54 AM
Silvertip Silvertip is offline
I doubt you will make much headway against a 3 MPH current although the motor will work fine otherwise. I have a 55 PD on my 18 footer and although I've not checked speed, I've run MinnKotas for years on my walleye boats and 5 MPH would be about tops. At that speed the motor is drawing somewhere in excess of 40 amps. Since you don't want to ever drain a deep cycle more than half way if you expect the battery to last, you would be advised to buy the largest capacity group 31 battery you have room for. But then it depends on how far you need to travel worst case. As you said, it is hard to predict the outcome since current, load, battery size, speed and distance are all factors as to whether you make it back to the dock or not. Dual batteries would certainly add some additional security if needed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Trolling Motor for Pontoon Boat OxMo Pontoons 9 December 28th, 2008 08:43 AM
Minn Kota Pontoon 65 trolling motor pboat Electrics, Electronics and Trolling Motors 1 May 20th, 2006 12:29 PM
trolling motor recomendation for 20' pontoon? tnimmortal Electrics, Electronics and Trolling Motors 2 March 20th, 2006 06:12 AM
Motor Guide Great White trolling motor question imported_Warren Electrics, Electronics and Trolling Motors 0 November 1st, 2003 10:36 PM
pontoon trolling motor geezer1960 Boat Topics and Questions (not engine topics) 4 June 18th, 2003 11:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
