  #1
Old June 9th, 2008, 11:02 PM
kevinpops kevinpops is offline
Default 1995 90hp mercury ob (speedometer, tachometer problem)
I have a 1995 mercury 90 hp outboard on my bowrider. It runs well enough.
Last year the speedometer worked just fine but since I have had the boat 2 years now, the tacometer has not worked. I have put a lot of money in repairs on the boat and since these are not necessitites I want to try to fix them myself.
Can anyone walk me though where to begin with either or both problems.
Thank you in advance.
Kevin
  #2
Old June 10th, 2008, 12:08 AM
Silvertip Silvertip is offline
Default Re: 1995 90hp mercury ob (speedometer, tachometer problem)
Let's do the speedometer first. This system has three parts 1) the speedometer head 2) the plastic tube that runs to the back of the boat, and 3) a pitot (pronounced "pit-oh"). The pitot is either built into the motor, or its the white plastic deal that hangs down at the back of the boat. The pitot has a small hole in it and it faces forward. As the boat moves through the water, water pressure acting on the air in the tube, compresses that air making the speedo needle move. No water actually flows through the tube. So - 99 time out of 100 the speedo head is not at fault. The tube is plugged, kinked, or disconnected at the back. But -- 99 times out of 100 the tiny hole in the pitot is plugged. Clean it and you are back in business. Just follow the tube back to the pitot or the engine.
As for the tach, they require +12V when the key is on, ground, and a sense or pulse line from the engine. A fourth wire is for the internal light if it has one. Check those connections. If you don't have +12V, ground, and the sense or pulse line the tach won't work. Nor will the tach work if the voltage regulator/rectifier is fried. If your charging system is working, then that's not the issue.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tachometer Problem on a 90HP Johnson Margarita Man Johnson & Evinrude Outboards 4 August 5th, 2007 11:30 PM
1995 90hp ob loss of power kevinpops Mercury & Mariner Outboards 1 July 28th, 2007 11:02 PM
1995 75hp Mercury ob trimmer in-op Belize Mercury & Mariner Outboards 3 June 27th, 2005 06:22 PM
1995 90hp force flooding problem ferg57 Force & Chrysler Outboards 9 May 4th, 2005 06:32 PM
Mercury Speedometer Problem scottwil01 Mercury & Mariner Outboards 8 July 23rd, 2004 03:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
