  #1
Old June 9th, 2008, 12:51 AM
IAB1965 IAB1965 is offline
Default 96 Bayliner Capri 1700 Special Edition 16’09 Floor Repair
This is my first boat and I really want to keep it at all cost… I am in the process of replacing my floor. Today, as I started cutting the fiberglass out to remove the wood, I discovered that someone had put plywood over the original floor and coated over it. After removing the fiberglass coating, the plywood was mushy and wet to include the original floor. (Was this model of Bayliner originally built with the foam on both sides of the floor? The reason why I ask this question, is once I got down to the original floor, it looked like holes were drilled into it and the foam was blown into it.) I continued to remove both sets of wood and found the foam to be completely soaked. It took me a good while to get the seating area removed. The stringer that goes horizontally at the rear of the storage area was completely rotten and the floor was holding up by the fuel tank.
Do I need to remove the foam since it is holding water? Also, do you think I need to replace my vertical stringers? They seem to be ok to me….. Since I removed the original floor is my structural part compromised?
What type of wood do I need to replace the floor with? If I need to replace the foam, what kind and where can I get it?
So far, I have enjoyed doing it myself. I look forward to completing the work and getting my boat back on the water.
Your help is greatly appreciated….
Thanks
  #2
Old June 9th, 2008, 09:22 AM
gcboat gcboat is offline
Default Re: 96 Bayliner Capri 1700 Special Edition 16’09 Floor Repair
First off welcome to the zoo!!!!!!
There is no way that your floor installation can be explained in one setting. Everyone has their own specific ways of doing things, type of wood to use, etc. However I'll give you some basic starting points.
Remove the foam ? Absolutely
Vertical stringers - might as well do them, you're going to be right there.
No structural integrity compromised.
Type of wood to use on the floor. Here comes the fun part. Lots and lots of different ideas on this little deal. Any boat that I touch gets Okume lumber for the decking. It is resin coated on both sides and the edges. If you use poly resin you will need mat. If you use epoxy then it won't be needed.
Do a Google search for marine grade foam. Again, a thousand different brands but they all serve the same purpose. Personally, I'd leave the foam out BUT someone who has better knowledge on it will hopefully reply.
Be prepared for a slew of different ideas on the deck lumber but whatever you use it must be completely dry. Resins won't bond well to anything damp.
I would suggest that you also consider posting your future questions on the boat restoration site. You'll get a lot more looker's there.
Good luck, have fun and remember not to get discouraged. It WILL come together one of these days.
Jerry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Bayliner Capri 1700 CR Tech Specs Greywolf58 Boat Topics and Questions (not engine topics) 5 June 22nd, 2009 04:16 PM
1991 Bayliner Capri 1700 LS Steering Troubles Egan Dolph Bayliner Boats 2 August 2nd, 2007 12:45 AM
1996 bayliner capri 1700 LS need help with floor!!! cgaviator Boat Restoration and Building 5 April 30th, 2007 12:26 PM
bayliner capri 1700 90hp prop slipping PERIKO Force & Chrysler Outboards 2 March 8th, 2007 07:13 PM
My Project - 1989 Bayliner Capri - floor repair Arnaldo Boat Restoration and Building 3 April 10th, 2006 08:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
