MomentSurf
- Oct 20, 2007
- 32
I own a 1981 9.9hp that isn't pumping water. I noticed a while ago it was pumping water inconsistently so I decided to check the impeller. I found some corrosion and made the below repair:
Now that I put it all back together it doesn't pump at all. I did a whole bunch of tests and came up with two problems I'm going to need some help diagnosing.
First-I took the lower unit off and noticed it had to be submerged up to the bottom of the impeller before it started to actually pump water. I tried using regular 'ears' but they didn't work. There is no clog. Could there be a seal problem where the impeller housing mounts (are you supposed to use any gasket material for that seal?) Or does the engine (sail model with the extended drive) need to be submerged that deep before it starts pumping? I thought all you needed submerged are the bottom holes (screened suction holes)..am I wrong?
Second-I found that when I blow some air or water up the copper pipe (the pipe the impeller normally feeds) the air/water does not come out the hole on the outside of the engine (where the exhaust and water spray out of, normally). Can that pipe be broken or corroded? I can hear the air coming out before the pipe reaches the bottom of the engine. How do you changed/test/inspect that pipe?
Thanks so much!
This is a link to a old thread.I own a 1981 9.9hp
Just made this picture:
-The engine has to be submerged up to that red arrow (just below that second fin) for the impeller to pump. Is that normal or is there a problem? (I found this out with the lower unit off - spinning the shaft with a drill). I put a set of ears on the lower unit and it didn't work at all (maybe the ears weren't making a good enough seal?? Square old ears that didn't fit the curve of the engine?)
-It seemed when I blew air in the pee hole (blue arrow) or in the water tube the air wasn't making it all the way through. I think the water tube isn't connected to the bottom of the engine (or broken) how do I get to it/inspect it?
Maybe I have two problems...hmmm HELP!!
Thanks.
Thanks so much!
Thanks.
