Getting everything together to swap engines and am thinking about anything else that I should do relative to the drive and so forth while I've got the engine out. I'm planning to redo the bilge, glass some gracks and chips etc... when I move the front engine mounts, put in with new rear mounts (thanks guys), etc...
Lower shift cable? Probably about time for one and assuming would be much easier to do with everything out of the way,
Anything else on the drive or drive assembly that makes sense to service or redo while I've got the drive and engine both out?
It's a 1988 version alpha 1.
Thanks.
Thanks.
