I followed the posted 'substitute' WOT timing protocols and found that my current setting was around 18-19 (+ the 4 factor = 22-23). I wanted to retard the timing to 16 (equals 20 as per manual) but I ran out of adjustment possibilities (only about two turns left) and could not change the timing much. I got it down about two units to around 18, so now my timing is theoretically set at 22 degrees.
This is still two degrees advanced past what it should be. Would it even run when set 4 degrees past the recommended setting as it was?
Before I started messing with this motor it ran fine on the upper end, I just had major starting and idling issues. Another clue: When trying to do a link and sync following the manual last weekend, I was setting the idle rpm to get 5 degrees BTDC, so I could line up my cam. But all I would get was about 0 degrees at a normal idle rpm. Increasing the idle did not change this much (1-2 degrees BTDC). I don't have a tach so I don't know how high I went up on my rpms but it was quite high (and I did have the motor submerged).
I read that having the timing advanced is not good for the motor and mine seemed to be set about 4-5 degress past where it should be. Both high and low readings were off by about the same amount.
