HELP!!!)
I had the boat out yesterday and it ran fine til the end of the day. I was going at low speed abut 2000 rpms when the engine just quit. Tried starting and it would'nt. So I let it sit for about 20 mins, and the only way it would start was to hold the choke at
full throttle after several attempts. I got it back to the dock and pulled the carberator
bowls off to see if they where dirty or the floats were stuck. They looked clean, so reassembled and it started up fine. Then I shut it off and had the same problem. I have a new water seperator filter, gas filter and last year rebuilt the fuel pump. Also after I got it started I took it out for a run and if I openened it up to full throttle it started to bog down.
