Re: Help! Evinrude 200 not shooting water...changed impeller too.
Is this on muffs or in the water?
I changed my impeller a while ago and it wouldn't pump on muffs even though it always had, put it on the water and it pumps like a champ.
Pull the hose off the tell tale and make sure it isn't plugged, pretty notorious for picking up stuff and plugging.
Yes it has tstats, you need to get an OEM manual to find out where they are, makes working on your motor so much easier.
__________________
GO IRISH!!!!
