Can anyone help, I had water in the gear oil so I have removed the water pump housing including impeller etc. However the drive shaft seals didn't come off when I removed the lower water pump housing and now remain on the shaft. The manual says they should have been stuck to the lower housing with loctite 271.
What's the best way to remove them without damaging the shaft etc?
Thanks
Thanks
