boomtime
- May 7, 2008
- 24
I recently picked up a small CC with a 1990 V4 90HP Johnson 2-stroke outboard on it. Im in the process of "improving" the boat with things like paint, new throttle/shift cable and new side mount BRP controls (these items are already replaced).
The other day i was out runnin around and noticed the motor started missing while i was cruising along at about half throttle. It was audible that the motor was not 100% there so i brought it down and let it idle a little and then hit it again and it started missing again. I drove it back to my dock this way without a problem and at this point im assuming its ignition related based on how the problem manifests itself. To that end i decided i would just replace the plugs and wires anyway to see if that remedies it and if that doesnt work i will probably buy 1 new coil and swap one side first to see if that remedies the issue.
Am i on the right track with my troubleshooting?
Anyone have any tricks or tips to offer on this particular motor for performance issues.
