  #1
Old June 6th, 2008, 09:03 PM
newellchunker newellchunker is offline
Unhappy Overheat alarm '93 225 Yamaha
OK, I finally got the new water pump kit installed put everything back together and fired her up on the muffs. Good amount of water from the telltale, got down from the boat and was actually feeling the heads with my hands (they were right warm) when after about 3 minutes I heard the alarm go off, got to the helm and it was the overheat alarm, immediately shut her down and then I checked the thermostats....there didn't appear to be any water up around the stats??? (I didn't have this problem (overheating) before I replaced the water pump kit. I have done nothing else besides water pump kit.) I dropped the lower again, and checked everything and it appeared OK. I have not run her again for fear of cooking her......any ideas or suggestions??
  #2
Old June 7th, 2008, 09:33 PM
Angry Re: Overheat alarm '93 225 Yamaha
Anybody out there?
Can you run this engine w/out the thermostats and outside covers to see if water is getting up there (w/out damaging it)? And will this help give any indication of my problems??
Thanks
  #3
Old June 8th, 2008, 09:13 AM
rodbolt rodbolt is offline
Default Re: Overheat alarm '93 225 Yamaha
no its not reccomended to run without the t-stats and no it wont give you an indication of your problem and will in fact create more.
why not simply do the entire job to include cleaning the pressure control pocket and replacing that $1.50 grommet and watch your issue dissapear.
most common reason for your issue is a stuck pressure control valve due to corrosion on the back of the grommet or debris in the valve. will dump water presure at low speeds and wont fill the block.
if the water pump was done correctly, and the T-stsats are good and the control valve is working the tell tale on a 2.6L V6 should almost dig a hole in concrete.
  #4
Old June 10th, 2008, 02:57 PM
Question Re: Overheat alarm '93 225 Yamaha
Rodbolt,
It had a weak telltale and after I cleaned the pressure valve decided to go ahead and order new valve, spring, gasket and also new water pump housing, thermostats and gaskets....this was a used boat and motor and the guy I bought it from had no idea of it's history....It had compression of 104-108 on each cylinder and seemed to shift fine...no water in the lower fluid. I was just performing maint. when this mess crept up on me.
Now, how and where do I install the fitting to add a water pressure gauge on the block or head(s)??? Pics and suggestions would be greatly appreciated!!
Also...how many ft/lbs per thermostat bolt and water pump housing bolt?
  #5
Old June 10th, 2008, 10:17 PM
dude
first off, grab a clue
I cant even type what I think of you.
FT LBS on a 6mm bolt? are ya smokin ?
why bother to do half the maint?
its all in the manual, tech guide and your owners manual.
me? I will admit, I dont torque the silly t-stat covers, 6 INCHpounds aint worth it.
common sense and reading the service manual will go a long long way baby.
I am not meaning to bust your chops, I am trying to make you understand that theentire subsystem needs periodic maint just as described in the book not repairs when its broke.
I dunno why you ordered so many parts, the new style valve cant stick but we are finding theywear out, the old style never did.
never saw a spring fail.
is your old pump housing melted? if not its another big waste of cash.
but its very common to see a water pump get replaced and it will cause the pressure control valve to stick open
on the pressure guage, careful what you wish for but the answer is in the marine tech guide and the rigging guide.
sometimes the plugs take out the threads after a few years of saltwater
sorry if I sound sarchastic, its been a long week so far. all I wish is my yamaha customers play and have fun, its what its all about.
  #6
Old June 11th, 2008, 12:09 AM
Quote:
Originally Posted by rodbolt View Post
dude
Well DUDE!!
What I am thinking of a you as a SUPREME PRICK right now! KNOW what I ain't got no stinking manual and that's why I was on here....so get a f----ing clue, grab yours nuts and chill. I wanted advice not a scathing attack.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
200 yamaha 1999 overheat alarm youick Yamaha & Suzuki Outboards 5 June 2nd, 2008 04:25 PM
2003 Vmax 225 engine overheat alarm at idle wally_williams Yamaha & Suzuki Outboards 3 May 6th, 2008 10:17 AM
93 yamaha alarm sounding sunpacman Yamaha & Suzuki Outboards 47 April 4th, 2008 01:00 PM
Yamaha TXRA150 overheat alarm andycastello Yamaha & Suzuki Outboards 8 November 2nd, 2005 06:00 AM
Johnson 225 overheat alarm 23robolo Johnson & Evinrude Outboards 9 April 3rd, 2002 03:25 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
