  #1
Old June 6th, 2008, 02:58 PM
AtlWtr AtlWtr is offline
Default Need new boat Battery
I bought a used Tahoe Q3 with a 3.0L, and the cranking battery has died. I have a deep cycle battery for the trolling motor. Not sure where the other electronics are hooked up. Is there a battery that is recommended? I see there is a wide spectrum to choose from. Thanks
  #2
Old June 9th, 2008, 06:22 PM
Default Re: Need new boat Battery
Let me try asking another way. Since I need a cranking battery should I just look on consumer reports and buy the best car battery?
The old one was an Interstate RV/Marine cranking battery. Any thoughts on this battery?
  #3
Old June 9th, 2008, 06:44 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Get the biggest CCA battery that you can fit,well worth the money
__________________
Chris
  #4
Old June 9th, 2008, 07:32 PM
bruceb58's Avatar
bruceb58 bruceb58 is offline
I would still buy a deep cycle battery for your cranking battery. I get mine from Costco. I use a deep cycle battery to crank over a 7.4L engine. It will be fine for your 3.0.
__________________
"Common sense is not very common"
1998 Wellcraft Eclipse 24 Cuddy
Volvo Pental Duo-Prop 7.4L "LK"
  #5
Old June 10th, 2008, 01:07 AM
DRIFTER_016's Avatar
DRIFTER_016 DRIFTER_016 is offline
Deep Cycle and Starting batteries are designed differently for different purposes. Buy a marine cranking battery for starting your engine.
A deep cycle battery is designed to be deeply discharged repetedly by slowly draining by a lower amperage draw like your boating electronics, trolling motor etc.
A starting battery is designed to quickly supply high amperage to start your engine. The draw is short in duration but intense.
Currently the best marine batteries are made by Optima. IMO
Buy the battery with the highest Marine Cranking Amps (MCA) that will fit in your mounting bracket.
  #6
Old June 10th, 2008, 02:06 AM
bruceb58's Avatar
A deep cycle battery is designed with thicker plates. Because of that, it can tolerate deeper discharges but puts out less peak current than a starting battery that is built with thinner plates that have more surface area. Will the starting battery deliver more current to start your engine...yes. Will the deep cycle battery be able to supply enough current to start your engine...also yes. As with any battery, deep cycle included, the less you discharge the battery before it is recharged, the longer it will last.
The Optima is a good battery but way overpriced for what it delivers.
__________________
  #7
Old June 10th, 2008, 04:27 AM
Boatist's Avatar
Boatist Boatist is offline
I agree with Bruse that a deep cycle will usually work fine as a starting battery unless you have a very large engine that is hard to crank. Yes the plates are thicker so you can not put in as many plates in the same size battery so slightly less current.
However I would buy a regular auto cranking battery unless your mounting it up front in the boat where they take a lot of pounding, then I would go marine.
The reason I like a auto cranking battery better is.
1: Much cheaper, go to Costco, Walmart, Sams club.
2: Auto cranking battery has a 3 year free replacement and 100 month pro rated warranty. Marine battery is 1 year free or less and 36 month or less pro rated warranty.
3: I like my boat cranking battery to be the same size and type as my tow vehicle battery, so batteries can be easily changed between boat and Truck. If anything needs to be changed I change the cables in the boat to be compatable with the truck. Never know when someone might decide they need your truck battery more than you.
As far as brand I buy what ever has the best deal. You can spend 3 times as much and the battery will last no longer.
What determins how long the battery last is not the brand it is how you care for your battery. Deep discharge it and let it sit before recharging and you will be lucky if it last a year.
Starting batteries should not be discharged below 80 percent of full charge and Deep cycles should not be discharged below 50 percent. The longer either is discharged before recharging the more damage is done. Also in hot summer month must recharge at least one time a month and winter every 2 to 3 month. Check the water level once a year and add distilled if necessary but also charge after.
I have not had a battery that did not last at least 6 years in my 1980 boat and My deep cycle is so old that I bought it back when price club still sold Delco Voyager Batteries
__________________
Have some fun and enjoy the Great Outdoors.
Love to fish out of Bodega Bay, California.
  #8
Old June 10th, 2008, 09:03 AM
dingbat's Avatar
dingbat dingbat is online now
I run a bunch of electronics and like having redundancy in powering them if need be. A starting battery will start the boat but will not run the electronics for long so I opted for a pair of deep cycle batteries. I run grp. 27 AC Delco Voyager Batteries and get very good life from therm.
I replaced one the end of last season after 7 years of service after I left the washdown pump on over the weekend which killed it. The second one is still has plenty of life left in it.
__________________
Grady White Seafarer
200 Evinrude Ocean Pro
  #9
Old June 10th, 2008, 11:13 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i have had great service for my interstate rv/marine starting battery. it has out lasted another battery i have. definately not trojan, i have had 3 fail in less than a year. i bought one, trojan just keeps replacing it. Dead Cells. it's a pita, to have to take it back.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New member, new boat, need some info on driveline? rdm190 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 21 May 13th, 2007 09:56 AM
When charging battery, do I need to disconect from boat? Bert1 Electrics, Electronics and Trolling Motors 5 May 29th, 2006 07:34 AM
need a new boat trailer winch: how do I know what weight I need? massimofinance Trailers and Towing 1 June 14th, 2005 08:34 AM
Need Input on New Boat Purchase... (First Time Boat Owner) TheChad Boat Topics and Questions (not engine topics) 10 June 2nd, 2005 05:22 PM
new boat needs new battery phatmanmike Electrics, Electronics and Trolling Motors 3 July 2nd, 2004 07:48 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
