  #1
Old June 6th, 2008, 10:46 AM
evin268fs evin268fs is offline
Default 115 Evinrude Intruder Carb, 60 degree
Lost my motor over memorial weekend, was running WOT trimed high and lite just me, 6000rpms, 1-1.5' chop running great, hit an unseen wake. Motor came out but didn't hear it wind up any higher. Know it came out cause when it caught popped the bow up pretty. Sad sound started soon after.
Mechanic believe cause of destroyed block is overrev, most here believe these engines like high rpm, Would the rev limiter not sure at this point of 6200 or 6700 or do you think it was the load/no load/load that borke these parts. Spin a bearing, destroyed a rod and shoot parts through the waterjacket? Was it the rpms you think or that it is a 10 year old motor and the bearing was on its way, bearing ate through about half of the crank as well. Should I prop it a little lower 5700 rpms to give a little more custion? (mechanics suggestion), lower motor for better bite?(my thoughts), try and get a 6200 limiter??? OR just an expensive lesson to trim down in rough water.
Said does not look like heat or lubricaction was a problem. ? Much smoother ride when trimmed up and on top however.
  #2
Old June 6th, 2008, 11:00 AM
Default Re: 115 Evinrude Intruder Carb, 60 degree
Also any recommendations for break in oil. I am about a half gallon into the semi-synthetic Fitch oil I had picked up, was running bulk XD-30, have read somtimes it is better to run Non-synthetic during breakin.
Also normally run seafaom, 1/2 can per 15 gallons, 2 out of every 3 tanks should I run this during break in??
Break in procedure recommendations also appreciated.
When Will it be able to pull skiers again, after break in, halfway through breakin in ect. I know slalom puts quite a load on the engine during starts? ?
  #3
Old June 6th, 2008, 11:08 AM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Which cylinder was it? What does the piston look like in that cylinder? What do the other pistons look like?
  #4
Old June 6th, 2008, 11:15 AM
3 banks look great, 123-125 compression, well lubricated
top passengerside bank, very low compression, small pieces of alluminum in it, said to be the debri from the bearing/rod, no mention of the pistons, so I assume they were not the casue, no mention of overheat or lack of lubrication.
Am getting, re-manufactured powerhead complete with crank, rebuilt carbs (standard on all thier rebuilts) and new waterpump
  #5
Old June 6th, 2008, 11:16 AM
said cylinders were very clean as well
  #6
Old June 6th, 2008, 11:22 AM
The clue is going to be the pistons. You'll need to know what the #2 piston (top port cylinder) looked like.
Also, what spark plugs were you running?
  #7
Old June 6th, 2008, 11:26 AM
It is at the shop but I believe they were NGK spark plugs, ran them for two years myself with them, never had to have them changed came from dealer in AR, that had all maint on the boat, I assume it was ran all ten years on these plugs.
I will ask to see if there was piston damage. When I call, baot is at the shop I now use at the lake about 2 hours away. Spun bearing caused by over rev is what I am told caused this mess
  #8
Old June 6th, 2008, 11:28 AM
What should I be looking for as far as damage to the piston?
  #9
Old June 6th, 2008, 11:33 AM
Make sure you run the correct plugs with the new powerhead. The 60* motors are pretty sensative about them.
Actually the bearing quit spinning, that's the problem. We've ran those bearings over 7000 rpm consistantly with no problems. It could be that a needle just quit spinning or there could be a cause.
Again, your pistons will be a huge clue but another thing they have to check is for water in the oil tank. Or water in the fuel, check the water seperator. I'm sure they'll change it anyway - that's standard in a replacement / rebuild.
  #10
Old June 6th, 2008, 11:41 AM
I had taken it in for a spring check up in March, change filters, lower unit lube, ect. Doubt there was water in the oil or gas, add seafoam 2 of every 3 tanks, never let it get lower than a quarter tank.
Only change is two or three tanks ago switched from full petro (3 gallons last year this spring)XD 25/30 bulk oil to a bottle of Fitch Synthetic blend they had on the chelf, have about third a gallon left and whatever is in the oil tank
Will ask to look at the piston when I pick it up
  #11
Old June 6th, 2008, 11:44 AM
What are the best most correct spark plugs if you don't mind me asking?
Secondly, at 10 years old would the bearings still be able to handle the extra high revving? Not like it is a race motor that get rebuilt often?
  #12
Old June 6th, 2008, 11:48 AM
The bearing should should have been fine. It may have been a freak thing or there may be a cause that can create a repeat performance on the new powerhead.
I'd sure look at the oil tank, even if you "doubt" there's water in it.
  #13
Old June 6th, 2008, 11:49 AM
Especially if it has a deck fill. It probably doesn't, most everybody has figured out the problems with those by now.
  #14
Old June 6th, 2008, 12:19 PM
Oil tank is plastic jug with cap under rear deck, should I have it emptied and start with new oil just in case?
  #15
Old June 6th, 2008, 12:22 PM
Is it possible that added stress from it going from full load and trim to no load out of the water, to loaded when it entered damaged the bearing/crank/rod as it started making noise within a few seconds, shut it down and trolled back but motor never died, restarted it once for about 3 seconds
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
95 intruder 150 bored to .40 over 60 degree motor bonitoman Johnson & Evinrude Outboards 7 November 22nd, 2004 12:27 PM
1995 60 degree 150 intruder lower unit hookless Johnson & Evinrude Outboards 5 August 29th, 2004 04:14 PM
150 60 degree intruder bonitoman Johnson & Evinrude Outboards 4 December 27th, 2003 08:00 AM
my shift rod on my 95 150 60 degree intruder is off about 1/4 inch bonitoman Johnson & Evinrude Outboards 16 November 1st, 2003 03:31 AM
1995 v-6 evinrude 150 intruder 60 degree bonitoman Johnson & Evinrude Outboards 0 July 24th, 2003 02:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
