josh studenny
- May 6, 2008
- 1
I have a 2002 185 sea ray and can't figure out why the fuse under the dash keeps blowing when i try to turn the buldge pump on. I know that its suppost to be a 7.5 amp fuse and also everything else on the boat works when i tried it. I checked the connection on the battery and it's ok. I payed for it to get winterized last year and this spring had some regular maint. done(remove outdrive check engine alignment and greese gimbal bearing and u-joints) but they never fired it up. I runs perfect and like i said everything else works, just wondering if maby there is a connection or ground that i cant see thats loose.
