I've finally received my Johnson Service Manual and have read through it.
I was getting ready to perform some of the basic carb linkage adjustments when I noticed a discrepancy.
The manual shows a solid link between the two throttles, while the choke link is two parts with an adjustment connector in the middle. Mine is just the opposite. My throttle-to-choke link is shaped different as well.
Is this a minor factory variation and to be ignored; or has someone slapped on different carbs; or worse, 'adapted the linkage'?
Plus it appears my Manual Choke lever assembly is missing. Will this affect the operation of the engine (other than I have no manual settings)?
thanks
thanks
