OK, assuming my cracked block isn't worth trying to fix with some JB Weld type stuff, what's the least expensive solution to replacing the block? I have read that i can use an automotive block (need to change the plugs, correct? with my other current engine parts and it will be marine OK. Correct or not?
Is there a time period I need to get to match the rest of my 1985 engine?
Mine is a 305 2bbl 200hp. I think it's just cracked externally. The mechanic said the engine at least idled fine but was leaking water like crazy out the crack. Does this mean there is a likelyhood that just replacing the block will be fine?
Thanks.
Thanks.
