YAM 2.5L V6 225 h/p age required - no serial plate :(
EDDYSTONE EEL
Yamaha autolube, 2.5l V6 225hp colured bluey grey with a "flash" style decal on the cover.
no plate on the transom bracket but on an engine core plug is 300554 (serial number ?)
Any one know its age pleazzz
thank you in advance for your expert help
EDDYSTONE EEL
Re: YAM 2.5L V6 225 h/p age required - no serial plate :( PIC INCLUDED
Hi All
Pic now included,
anyone care to hazzard a guess of the year, thank you
rodbolt
as Yamaha never made a 2.5L V6 2 stroke for the US market I cant help. close pics of the port and stbd sides of the powerhead will be an aide, paint color is meaningless.
EDDYSTONE EEL
Sorry my mistake its a 2.6 ltr,
another pic below, will get those pics you asked for,
cheers
care to guess its year ??
rodbolt
ill try again.
as quite a few years of hoods interchanged as well as powerheads to midsections the only way we can give you a clue is you have to give us some,
good pics of the port side of the carbs,the stbd side of the engine with the hood off and the back side of the engine with the hood off.
that way we can get an idea of which ign system its running and is it prime start or not. as well as does it have 6 pulsers and a movable timer or two pulsers and a crank position sensor.
Ray Neudecker
It is not a model that was sold in the US. No way to even guess the dating of the model without seeing pics of the powerhead. The US version of the 225 was called an Excell with a different cowling in 87.88 amd 89. The newer style cowling was used from 1990 on in the US.
BruceAML
Would you care to tell us what country you are in and the country that the motor came from? Do you have any papers for this motor? As an educated guess, I would say your motor is from 1985.
EDDYSTONE EEL
Hi, Its a european unit
More pics enclosed of the powerhead etc. Your guesses are much welcomed
thank you
BruceAML
How about 1991?
Ray Neudecker
The powerhead and electrics are the same as the 87-89 Excells sold in the US. The electrics were changed on the 90 model and later versions.
