LightningKeith
- May 4, 2008
- 3
Hi guys! I'm new to the forum, and I thought maybe you guys can help me. I have an older boat with a 200hp evinrude 2-stroke. (I think its 1977). Anyway, had it out on the water yesterday and everything was running fine... until I noticed that when I went to start the motor, the starter wouldnt crank. I tried it a couple times, and played with the key until it cranked again. I figured it might be the ignition switch, so I replaced it today, but the motor still wont crank. (However when I push the key in I cal clearly here the choke solenoid). I have tested the battery, and everything is fine on that end. I'm thinking it could be the starter/solenoid or maybe some type of safety switch? I'm new to outboards, so any ideas are greatly appreciated.
Note: I'm not sure if there is some type of reverse safety switch or something, but I was in reverse when I gave the motor some gas and it died. After that it doesnt crank at all. I'm not sure if that is a coincidence or if it has something to do with my motor not starting.
Thanks!
Keith
Thanks!
Keith
