Re: Crank Shaft Removal?
Normally, the drive shaft is stainless steel and the crank is steel. So, if anything rusts, it's going to be the crank. Of course, then the rusty/worn crank splines are a lousy fit on the drive shaft so the drive shaft splines wear by association.
