  #1
Old June 3rd, 2008, 12:04 PM
*WEAVER* *WEAVER* is offline
Default Mercury low oil sensor question.
I recently bought a 1990 90 horse mercury with oil injection. Whenever I plug in the sensor that is coming from the oil tank, there is a loud constant beep when I turn the key on. I read where this is a low oil sensor, but I filled the tank, and it still does it. Any ideas on what might be the problem on this? Thanks
  #2
Old June 3rd, 2008, 12:32 PM
Laddies Laddies is offline
Default Re: Mercury low oil sensor question.
The magnet came off the float, you will need a new tank as it's not repairable
  #3
Old August 8th, 2009, 10:18 PM
superfluke superfluke is offline
i have a 91 ranger with a 150 blackmax and has recently started beeping continously when running down the lake. i have been told its the sensor or the module. i put a tester on my sensor and seems to work but have read that the washer is supposed to be attached to the float and mine is not.what should i do and do i also have to get a new sensor for my oil resovoir on my engine? THANK YOU--superfluke
  #4
Old August 8th, 2009, 10:59 PM
Timothy's crestliner Timothy's crestliner is offline
Its definitly a very annoying beep. An idiot light might've been better. I disconnected the buzzer. Probably not the smartest thing to do, but as long as I keep an eye on the oil level, and the tell tale, the motor ought to be ok.
I do worry though, i've heard of the oil injection going out on these though..
__________________
15' 1974 Canbar Crestliner tri-hull boat.
90HP 1989 Mercury 2 stroke, 3 cylinder oil injection.
  #5
Old August 9th, 2009, 10:48 AM
j_martin j_martin is offline
Yep, if the alarm goes off, disconnect the buzzer. If an idiot light keeps coming on, just cut the wire.
When the power head grenades, it'll be the oil injection system's fault.
Amazing logic displayed here.
my 02
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
115 HP Yamaha low oil alarm/sensor tadpole1965 Yamaha & Suzuki Outboards 1 May 31st, 2008 08:23 PM
VRO, low oil sensor won't stop buzzing andy6374 Johnson & Evinrude Outboards 5 September 14th, 2005 11:04 PM
Low Oil alarm, problem with sensor? gjgardner Mercury & Mariner Outboards 5 June 28th, 2005 10:52 AM
High heat/ Low oil sensor Fontaine Mercury & Mariner Outboards 0 June 15th, 2003 07:14 AM
Should there be constant voltage through a low oil sensor? pchurch Johnson & Evinrude Outboards 6 August 20th, 2001 04:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
