  #1
Old June 3rd, 2008, 11:29 AM
Jimdsi Jimdsi is offline
Default 1995 200HP Evinrude VRO pump ?
I am having a problem with this engine. From the first time I ran it this year, it will not stay running after I get it started. It will run for a minute or 2 then peters out and dies. I have replaced the spin on fuel filter/ water seperator and the in line fuel filter in the engine. When I hooked up an external fuel tank, it ran a little longer but still died. The primer bulb does not collapse and the fuel restriction (vacuum) alarm does not sound. I did notice two things however. The clear in line filter always has some air trapped in it, and goes dry before the engine stalls. Also, if I squeeze the primer enough times, I get some gas leaking from the top of the VFO assembly from what looks like a vent. I'm not sure it really is a vent, however. I have found OMC part numbers for VRO repair kits that include diaphrams and rubber gaskets, but I have not been able to locate anyone who has these kits. I'd hate to gamble $300.00 on a pump that may not be the problem. If I was sure it was the VRO pump, I'd bite the bullet and get one.
Am I on the right track about the VRO pump? Does any of this sound familiar? Anyone know where I can get the VRO repair kit?
  #2
Old June 3rd, 2008, 03:09 PM
Chris1956 Chris1956 is offline
Default Re: 1995 200HP Evinrude VRO pump ?
Jim, Your problem could be as simple as an air leak in the gasoline line. Check the fuel screen where it screws onto the vapor seperator. Make sure the oring and gasket are in good shape. Check the pulse line and pulse limiter and make sure they are clean and seal properly. I assume the clear inline fuel filter is aftermarket? If you have a water seperating fuel filter you do not need any other filters. Remove all the aftermarket ones, and use one piece fuel line to eliminate leakage points.
  #3
Old June 3rd, 2008, 04:00 PM
CharlieB CharlieB is offline
VRO's do NOT leak or vent, replace the pump.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1995 200HP Evinrude starts, dies, VRO ? Jimdsi Johnson & Evinrude Outboards 1 June 2nd, 2008 01:47 PM
VRO disconnect - Johnson 200HP 1995 txlunker Johnson & Evinrude Outboards 9 June 19th, 2007 10:06 AM
VRO Bypass Instructions - 1995 200HP Johnson txlunker Johnson & Evinrude Outboards 0 June 19th, 2007 01:17 AM
1995 Black Max VRO pump chuckonaol Mercury & Mariner Outboards 1 October 27th, 2006 03:37 AM
1995 200HP Evinrude head removal ?? Jimfor Johnson & Evinrude Outboards 1 September 14th, 2005 07:57 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
