  #1
Old June 3rd, 2008, 08:25 AM
hkgboater hkgboater is offline
Default mercury 140hp 2006 water pump question
recently flushed the engine with fresh water after use, with the engine running and the muffs fitted the hose came off so no water to engine.engine proberbly ran for max 1 min at idle before I turned it off.
1.what is likelyhood of damage to the waterpump / engine?
2.what do I need to do before running it again?
  #2
Old June 3rd, 2008, 01:48 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: mercury 140hp 2006 water pump question
The motor probably did not overheat and is likely fine. Aside from a visual inspection of the motor for signs of melting wire and such, you can do a compression test of the cylinders for peace of mind. The impeller in the water pump, however, may have been damaged or weakened by running it dry. Even if you did a water pressure test on the cooling system and found it within specs, you can't predict how long the impeller would last if it was weakened. If it were my motor, I would replace the impeller.
Others that have actually done what you did may provide more "real-life" opinions on how likely the motor survived this experience.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 Mercury 402 Water pump question mrcorrao Mercury & Mariner Outboards 3 July 13th, 2009 07:15 AM
2006 Mercury 115 has water in oil, why? morriscrazy Mercury & Mariner Outboards 2 May 17th, 2008 08:33 AM
evinrude 140HP water pump edthearcher Johnson & Evinrude Outboards 3 October 8th, 2007 10:05 PM
mercury 7.5 thunderbolt water pump question sledge Mercury & Mariner Outboards 4 August 29th, 2006 06:26 PM
60's Mercury 6hp water pump question nick.wright Mercury & Mariner Outboards 1 August 9th, 2006 10:28 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
