maxum247
- Sep 18, 2007
- 1,363
Manual states that the idle tube in the carbs (must contact the front of the main nozzle).
The idle tubes on my 1989 125 Force are center of the nozzle. The caruretors are original since new and have never been rebuilt.
Manual states that if contact is not made with the nozzle the carburetors will operate excesively lean.
I also recently purchased a set of used carbs and the idle tubes are center of the nozzle also.
Could time and use have changed the position of the idle tubes in the nozzle?
Is this something I should be conerned about? Thanks!
