Re: Evinrude 50 faster than johnson 48
I smell a dirty carb, just for grins take an eye dropper or something you can squirt a small amount of gas into each carb whike it is running so e throttle and see if it doesn't run better for a second, you will have to pull the intake cover to get access to the throat, if not that will rule out the carbs as a cause.
I had a similar problem last year, pulled plug wires, replaced all kinds of parts turned out to be a dirty carb, and I had "cleaned" them twice, just not right.
It idled perfect and you couldn't hear a miss but it was running in one cylinder the whole time.
After spending $100+ on parts it turned out to be the high speed jet in the bottom carb
Pay special attention to the high speed jets, pull the drain plugs on the float bowls they are inside the drain holes and you will need a really skinny screw driver to take them out, run a stranded copper wire through them a couple times and there you go.
Always check the free stuff first.
My 2 cents
