i have a 95 Evinrude 150 and all 6 carbs are leaking. They are leaking from the little plug or ball on the bottom of the fuel bowl. When I pump up the primer they just ooze gas out of them. I wipe them dry and in a minute or two you can see them oozing. The ywill drain the fuel bowls in a few hours. I have the boat out of the water now and it is dripping out of the cowl onto the lower unit. I did notice this some last year and did not think much about it. I now have all 6 carbs on the bench and they all leak. Can I just reseat the ball and reseal the hole. There is some type of sealer that came out pretty easy. Here are 2 pictures of the one carb.
