  #1
Old May 30th, 2008, 01:43 PM
philtallman philtallman is offline
Default Mariner 9.9 m ignition problems
I have a 9.9m serial # 682CS05XXX that has no spark. I think it is a bad coil because the primary reads almost 0 ohms and neither plug wire has any reading to ground. the plug wires have 3.7Kohms between them.
Can anyone verify my suspision? Any recomendation when to get a relpacement? The coil has the part number CM62-22 CDI B.
I would also like to know if anyone can tell me year from the serial number.
Thanks,
Phil
  #2
Old May 31st, 2008, 11:00 AM
CharlieB CharlieB is offline
Default Re: Mariner 9.9 m ignition problems
Phil,
Before you order that coil remember there is no return on electrical parts.
A DVA Meter is the preferred tool to test stator, trigger and ignition module outputs to isolate your ignition problem.
The process of elimination works well and saves you many dollars over trial and error part replacement.
  #3
Old May 31st, 2008, 12:02 PM
Thanks for the warning. What is a DVA meter and how do you use it to test those components?
Thanks,
Phil
  #4
Old May 31st, 2008, 12:54 PM
Laddies Laddies is offline
Yes. If you want the year of the engine post the serial number.
  #5
Old May 31st, 2008, 03:36 PM
the serial # 682CS05551
Thanks,
Phil
  #6
Old May 31st, 2008, 04:29 PM
All 9.9C engines were 6 digits so presuming that the S is a 5 your engine is a 1983
  #7
Old June 24th, 2008, 12:47 PM
I missed a number that was hard to see. The serial number is:
682CS 051551
Is it still the same year.
I think this is a Yamaha power head, do you think the coil for a Yamaha would be the same?
Thanks,
Phil
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 mariner 175 efi ignition problems? Dewey Mercury & Mariner Outboards 13 April 27th, 2008 04:47 PM
Mariner Ignition CCM1001 Mercury & Mariner Outboards 0 July 22nd, 2006 05:06 PM
40hp Mariner/Yamaha ignition problems PACERll Mercury & Mariner Outboards 0 March 24th, 2005 12:27 AM
30 HP Mariner Ignition Problems schuh Mercury & Mariner Outboards 2 October 4th, 2003 10:38 PM
Mariner 40 (2cyl) problems with ignition coils mattclubb Mercury & Mariner Outboards 6 February 20th, 2003 05:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
